TwinTurbo.NET: Nissan 300ZX forum - Should be able to do everything in less than 3 hrs....
Subject Should be able to do everything in less than 3 hrs....
Posted by 300zx90 on April 07, 2005 at 1:13 PM
  This message has been viewed 502 times.
In Reply To How long did that take you, including removing the subframe? (n/m) posted by doug8867 on April 07, 2005 at 12:09 PM
Message The bushings themselves I can do all four in less than half an hour. Probably an hour to drop and reinstall the subframe. Put the whole car up on jack stands, remove the exhaust as one complete assembly (pretty easy on an NA, haven't done it on a TT), disconnect the driveshaft, disconnect the e-brake cables, unbolt the calipers (do not remove the brake line), remove the lower shock bolts, remove the four subframe nuts (and four bolts for the front plates), and the whole shebang drops right out (lower it on a jack with the help of a friend or two to steady it and guide the shocks).
I changed the diff bushings while the subframe was out, that adds another hour to it.
________________________________________
NA to TT, starting from the ground up...
